Simple tranformation during ETL, transform INT type to BOOL
  • October 14, 2013
  • 12 views
I'm a starter and would like to know how to perform a simple transformation in FME desktop edition. My source data has a INT column filled with data ranging 1 to 5. I wish to do an ETL and would want to Write this column to be a boolean in my destination database , such that 1 = TRUE(0) and 2 to 5 = FALSE(1).
How can I achieve this in FME?
Thanks
Best answer by takashi
Yeah, the AttributeValueMapper could be simpler in this case; you can specify FALSE(1) to Default Value, map 1 to TRUE(0).
# I found the FME Evangelist blog has moved to the Safe Software Blog (About FME category). Have you known?
http://blog.safe.com/
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
  • October 14, 2013
This article is describing the usage of several transformers which you can use to do that.
FME 2013-SP1: Conditional Processing in FME
http://blog.safe.com/2013/03/fmeevangelist113/
I would use "Conditinal Mapping" functionality of the AttributeCreator (FME 2013 SP1 or later).
Takashi
fmelizard
Forum|alt.badge.img+19
  • October 14, 2013
An alternative to Takashi's method would be using the AttributeValueMapper.
Itay
  • October 14, 2013
fmelizard
  • October 14, 2013
Yes, they have moved it and merged all Safe blogs into one some time now.
