Shortest path between many points and one destination
  • Oct 24, 2017 2:01 PM UTC
  • 5 replies
  • 153 views
Hi!
I am trying to find the shortest paths between many points and one destination, any idea on how I can easiest do this? I would like to reach a similar effect as v.net.distance in QGIS. I have looked at shortestpathfinder and networkcostcalculator, but I cannot see how I should use them, or which other tools to combine them with, in order to reach my goal.
danilo_fme
Forum|alt.badge.img+58
  • Oct 24, 2017 2:09 PM UTC
Hi @elinbr,
You can use the transformer NeighborFinder.
This transformer generate the attributes:
Thanks,
Danilo
  • Oct 24, 2017 2:11 PM UTC
Here's a good walk-through of the ShortestPathFinder and how to use it:
https://knowledge.safe.com/articles/28065/shortest-route-calculations.html
Here's an older video for FME 2013, but I think most of it still applies:
https://www.youtube.com/watch?v=5BzxKw_LONE
Let us know if you have specfic questions.
  • Nov 3, 2017 2:21 PM UTC
Hi!
Thanks! However, I need the equvalence of v.net.distance in QGIS. Is that not possible in FME?
  • Nov 3, 2017 2:32 PM UTC
Hi!
Hi again! Okay I see, I need to first create lines between my from-Points and my to-Point. Thanks again!
gio
Forum|alt.badge.img+15
  • Nov 3, 2017 4:07 PM UTC
Assuming you have a network (maybe road centerlines). You create points on the network by for instance neighborfinder or buffering and overlayers.
Create a from to by merging all from's to to's (unconditionaly merging
many points to your one destination)
Then use the shortest pathfinder.
