SharePoint: Updating Individual Fields of a Record
  • Mar 4, 2021 1:01 PM UTC
  • 64 views
townest
Forum|alt.badge.img+4
I see how to update individual fields of a record in a database at https://community.safe.com/s/article/update-only-certain-columns-in-a-database-table which seems straight forward enough. However, when I try this workflow on a SharePoint List I get an error. Does anybody know if this workflow works with SharePoint? If not, any pointers on how to update individual fields in a SharePoint List? Thank you.
townest
  • Mar 4, 2021 2:10 PM UTC
I just got it working with the workflow described. I had to use the SP item id as the key which is odd but worked. Also, the change detector detects a change on every run which is odd also, since there is no change on the second run, although it doesn't seem to affect anything. Any ideas why I'm seeing both of those behaviors.?
thank you,
Tyler
