Set working directory in SystemCaller...
  • Feb 27, 2019 8:39 PM UTC
  • 7 replies
  • 212 views
harmen_kampinga
Hi all,
With the SystemCaller I am kicking off an executable
That executable is looking for a file with parameters in the working directory
So if I use the Command Line in Windows, I go to D:\\TEMP
That then is my working directory and it has the parameter file : parameter.ini
When I start the executable it uses this ini file
But when I use SystemCaller and I set the working directory, the executable seems not to find the .ini file somehow
Anyone an idea?
I now use the PUSD command to set the working directory
Then starting the executable
Then close the command string with POPD
erik_jan
Forum|alt.badge.img+26
  • Feb 27, 2019 9:19 PM UTC
Have you tried:
CD D:\\TEMP
D:
That would change the directory followed by changing the device drive to D.
That is the way it is done in the CMD window and the SystemCaller should work the same way.
harmen_kampinga
Have you tried:
CD D:\\TEMP
D:
Unfortunately that doesn't work @erik_jan
But thanks for your reaction!
  • Feb 28, 2019 7:15 AM UTC
You could always try to use a batch file in the SystemCaller.
Otherwise you should consider contacting the developers of the executable, to better understand how it looks for the .ini file.
itsmatt
Forum|alt.badge.img+48
  • Feb 28, 2019 9:15 AM UTC
heya @HarmenKampinga,
To make sure that the SystemCaller is correctly changing the path you can use the following system call after the creator:
cd C:\\ && DIR && cd D:\\ && D: && DIR
In the FME log window you should should see the first the directory list of the C drive, followed by the Directory list of the D drive.
I would also echo David's comment here on how it looks for the parameter file if you're not having luck
harmen_kampinga
Yeah, that's also the direction my developer is pointing at
He also changed the executable, so I have now parameters to work with
Let's see what happens then
harmen_kampinga
Hi @virtualcitymatt ! Thanks for your suggestion
Now our developer has changed something in the executable, I'll have a try with that first
Keep you all posted!
harmen_kampinga
the executable was changed so a parameter can be added that point to the ini file
that parameter I am using now in the SystemCaller
Our developer also suggested at first the batch file, but adding the option is a better solution.
Your answer is the closest to the solution.
Thank you, @david_r, and also @virtualcitymatt @erik_jan again! Have a nice weekend!
