set sketchup trait for sketchup group name in Outliner
  • May 9, 2020 1:33 PM UTC
  • 5 replies
  • 137 views
kidega
Forum|alt.badge.img+9
I wounder if it's possible to set custom name of sketchup groups in the Outliner, using i.e. GeometryPropertySetter and "Traits from attribute"? Basically the same as setting the sketchup_layer_name as trait. I have mananged to group objects using aggregator.
I tried to solve it by the suggested solution on this tread: https://knowledge.safe.com/questions/2300/writing-multipatch-features-to-sketchup-groups.html
but couldn't get it to work. Any suggestions are appreciated. Thanks!
Best answer by alyssaatsafe
Hi @kidega, have you tried using the "Geometry Name" for "Property to Set" in the GeometryPropertySetter instead? I wonder if that would work for you.
  • May 13, 2020 12:34 AM UTC
kidega
  • May 15, 2020 6:25 PM UTC
Hi @alyssaatsafe,
Thanks for your suggestion of using "Geometry Name". That did the trick. I used GeometryPopertySetter just after the Aggregator.
kidega
  • May 16, 2020 8:15 AM UTC
Hi @alyssaatsafe,
Do you know if it's possible to also set "Angle between normals" and the option to set "smooth normals", "soften coplanar" in sketchup?
nampreetatsafe
Forum|alt.badge.img+14
Hi @alyssaatsafe,
I don't see an obvious way of setting these sketchup parameters in FME. Feel free to add an idea for this functionality, detailing your intended usage.
kidega
  • May 21, 2020 9:53 PM UTC
Thanks for the link with adding Idea. The intended usage is to write a sketchupfile as a template with buildings and terrain with different angle between normals for visual effect and easer reading of those geometries.
