Seperate a single field values into two xml elements??
  • Sep 12, 2017 10:46 AM UTC
  • 119 views
Hello Everyone, I have a field which contains table and column name together for Foreignkey using (,) and (#) seperators. I have created also List on this field already, now i am not understanding how I can make another list for getting those values.
Now my result XML is looking like :
bnr:table > element is getting all the table and column names now, but i want to see my XML as follows:
A partial coding of my XML template is as follows:
<bnr:MD_DataSchema>
let $n := xs:integer(fme:get-attribute("_element_count")) - 1
for $i in (0 to $n)
let $aname := "_list_name{"||$i||"}.Spalte"
let $atype := "_list_name{"||$i||"}.Datentyp"
let $descrip := "_list_name{"||$i||"}.Beschreibung"
let $fkey := "_list_name{"||$i||"}.Tabellenbeziehung"
let $mval := "_list_name{"||$i||"}.Fehlende_Werte"
return
if (not(fme:get-attribute($aname) eq "")) then
<bnr:column>
<bnr:MD_Column>
<bnr:tableName>
<gco:CharacterString>v140_mun.dbo.{fme:get-attribute("Tabelle")}</gco:CharacterString>
</bnr:tableName>
<bnr:name>
<gco:CharacterString>{fme:get-attribute($aname)}</gco:CharacterString>
</bnr:name>
if (not(fme:get-attribute($descrip) eq "")) then
<bnr:description>
<gco:CharacterString>{fme:get-attribute($descrip)}</gco:CharacterString>
</bnr:description>
else(<bnr:description>
<gco:CharacterString>No description</gco:CharacterString>
</bnr:description>
<bnr:dataType>
<gco:CharacterString>{fme:get-attribute($atype)}</gco:CharacterString>
</bnr:dataType>
if (not(fme:get-attribute($mval) eq "")) then
<bnr:missingValue>
<gco:CharacterString>{fme:get-attribute($mval)}</gco:CharacterString>
</bnr:missingValue>
else(<bnr:missingValue>
<gco:CharacterString>No Missing Value</gco:CharacterString>
</bnr:missingValue>
if (not(fme:get-attribute($fkey)eq "")) then
<bnr:foreignKey>
<bnr:MD_ForeignKey>
<bnr:identifier>
<gmd:MD_Identifier>
<gmd:code>
<gco:CharacterString></gco:CharacterString>
</gmd:code>
</gmd:MD_Identifier>
</bnr:identifier>
<bnr:table>
<gco:CharacterString>{fme:get-attribute($fkey)}</gco:CharacterString>
</bnr:table>
<bnr:column>
</bnr:column>
</bnr:MD_ForeignKey>
</bnr:foreignKey>
else ()
</bnr:MD_Column>
</bnr:column>
else ()
Best answer by takashi
Hi @mjoarder_pln, you can use the XQuery "fn:tokenize" function to split a string. For example, the partial expression that creates <bnr:foreignKey> elements can be replaced with this expression. Note: <bnr:foreignKey> elements would not be created if fme:get-attribute($fkey) was empty.
    for $k in fn:tokenize(fme:get-attribute($fkey), '#')
    let $s := fn:tokenize($k, ',')
    return
    <bnr:foreignKey>
        <bnr:MD_ForeignKey>
            <bnr:identifier>
                <gmd:MD_Identifier>
                    <gmd:code>
                    </gmd:code>
            </bnr:identifier>
            <bnr:table>
                <gco:CharacterString>{$s[1]}</gco:CharacterString>
            </bnr:table>
            <bnr:column>
                <gco:CharacterString>{$s[2]}</gco:CharacterString>
            </bnr:column>
    </bnr:foreignKey>
Hope this helps.
  • Sep 12, 2017 2:03 PM UTC
    return
    <bnr:foreignKey>
        <bnr:MD_ForeignKey>
            <bnr:identifier>
                <gmd:MD_Identifier>
                    <gmd:code>
                    </gmd:code>
            </bnr:identifier>
            <bnr:table>
            </bnr:table>
            <bnr:column>
            </bnr:column>
    </bnr:foreignKey>
Hope this helps.
    return
    <bnr:foreignKey>
        <bnr:MD_ForeignKey>
            <bnr:identifier>
                <gmd:MD_Identifier>
                    <gmd:code>
                    </gmd:code>
            </bnr:identifier>
            <bnr:table>
            </bnr:table>
            <bnr:column>
            </bnr:column>
    </bnr:foreignKey>
Hope this helps.
Hi , Takashi, it works ! great, thanks a lot !
