Select specific IFMEFace from solid for naming
  • Jul 3, 2018 12:41 PM UTC
  • 60 views
harmen_kampinga
How to select a specific IFMEFace from a solid?
I have created a solid and want to extract face 0 and face 5. I like to have them have a name. Later on would use those names to assign a specific texture to those two faces.
"Part 0: IFMEFace " should have a name like "roof"
  • Jul 3, 2018 1:54 PM UTC
Hi @h1, the GeometryPropertySetter with this Geometry XQuery does that.
Geometry XQuery (Enter with Advanced Mode)
for $geom at $i in //geometry[@fme_geometry_type = 'IFMEFace']
where $i = (1, 6)
return number($geom/@fme_id)
Note that item indices are 1-based in XQuery expressions.
harmen_kampinga
I will have a look at it @takashi , thank you!
harmen_kampinga
It works great! Played around with it. Thanks!
