Select polygon between other polygons (source: the same layer)
  • Jun 5, 2023 6:29 AM UTC
  • 45 views
marta.podsiad
Forum|alt.badge.img+12
I am trying to select a polygon located in between other polygons. All polygons are saved in the same layer. Either NeighborFinder or AreaOnAreaOverlayer do not provide the result I am after.image
Best answer by itsmatt
Here's something pretty basic which checks for touching polygons. Not sure is this will work for your workflow
itsmatt
Forum|alt.badge.img+48
  • Jun 5, 2023 8:40 AM UTC
marta.podsiad
It works. Thank you very much
