Select highest value from 1 column using and ID from another column
  • Jan 29, 2020 3:48 PM UTC
  • 7 replies
  • 415 views
I need to build something in FME where it automatically selects all ID entries and then looks at another column with values and selects the row with the highest value, and delete the other rows with the same ID. in the screenshot i have 2 columns: Risicoprofiel_BEREK and ID, in ID there are multiple entries which i need to select and then find the highest value from the Risicoprofiel_BEREK column.
Forum|alt.badge.img+54
  • Jan 29, 2020 3:51 PM UTC
You can sort by Risicoprofiel_BEREK in descending order and then use a duplicatefilter with a Key attribute of ID to just keep the row with the highest value.
erik_jan
Forum|alt.badge.img+26
  • Jan 29, 2020 3:53 PM UTC
I would go this way:
Use the Sorter transformer to sort by ID and Risicoprofiel_BEREK (descending)
Then use the Sampler (Sample first 1) and group by ID.
The sampled output port will give you the result you need.
Hope this helps.
mark2atsafe
Forum|alt.badge.img+59
The simplest method would be to sort the data with a Sorter transformer (sort by Risicoprofiel_BEREK) and then a DuplicateFilter (filter by ID). Then the ID with the highest Risicoprofiel number will pass and the rest are discarded.
As long as you don't mind the records being in a different order, then that would work fine.
mark2atsafe
Three answers in five minutes all giving the same solution (more or less). I guess it really must be the right way to go!
  • Jan 30, 2020 8:07 AM UTC
thanx for your help guys... i got it working! :)
  • Jan 30, 2020 8:17 AM UTC
will this also work if there are like 3 or 4 entries with the same ID? it will always take the highest?
  • Jan 30, 2020 9:20 AM UTC
Yes, as long as they are sorted from highest to lowest, the first feature with each ID, i.e. the highest, will always be kept
