Select AND Replace with a RegEx Expression
Hello,
I have an attribute that has values like this (the attribute itself is RegEX expression):
^[1-9]{1}[0-9]{1-3}[1-9]{1}[0-9]{5-7}$
In this attribute I want to replace all - that are within {} with a ,
I tried using the String replacer by first selecting all curly brackets with dashes, like this :
\\{\\d-\\d\\}
And then replacing it with this:
\\{\\d,\\d\\}
But of course it does not work cause you cannot replace with regex.
Any ideas?
Thanks !
Best answer by gio
@draganasubotic1
You can use stringreplacer, Replace Regular Expression.
regexp:
({[\\d])-([\\d]})
and replacement
\\1,\\2
Everything between brackets is a capture, of which there are 2 in this case.
Captures can be referred to by slashes, \\1 is first capture.
denizturan1985
Participant
I guess you want to replace all dashes which are in the curly brackets with "," (comma).
You can use the expression below:
(?<=\{\d)\-
gio
Forum|alt.badge.img+15
  • May 25, 2018
@draganasubotic1
regexp:
({[\\d])-([\\d]})
and replacement
\\1,\\2
Thanks a lot, both answers were very helpful!
