search regex with python caller
  • Oct 9, 2019 8:26 AM UTC
  • 5 replies
  • 56 views
Hello,
I want to find a regex with python caller.
The text_line is like Híd neve: Líra utca -  gyalogos híd. And I want to get only: Líra utca -  gyalogos híd
I was able to do it with StringSearcher, where the expression for the regex was like : (?<=Híd neve: )\w.*
Now I am tring it within python, but it doesn't give back value (it should be like: Líra utca - Ördög-árok feletti gyalogos híd)
Could you help me, where is the mistake?
class FeatureProcessor(object):
    def __init__(self):
        self.comp_re = re.compile("(?<=Híd neve: )\w.*")
        #pass
    def input(self,feature):
        text_line = feature.getAttribute('text_line_data')
        matches = self.comp_re.findall(text_line)
        if matches:
            feature.setAttribute('PyTrackExtents', matches[0])
        self.pyoutput(feature)
  • Oct 9, 2019 9:13 AM UTC
I was able to get your desired result from the script you posted.
Perhaps you just need to expose the new attribute name "PyTrackExtents'. See @egomm's answer to this question.
How to write an attribute into a new attribute with Pythoncaller
  • Oct 9, 2019 10:21 AM UTC
for me it is like this:
  • Oct 9, 2019 10:30 AM UTC
For me it is like:
  • Oct 9, 2019 10:47 AM UTC
It looks, the python script doesn't work with accentuated letters, because when I am looking for only the 'H', it gives back values.
Can you suggest mes some advice to modify the script to work also with accetuated letters?
Forum|alt.badge.img+54
  • Oct 9, 2019 11:00 AM UTC
It's probably an issue with the encoding
Try altering the first part of the python
    def __init__(self):
        self.comp_re = re.compile(ur"(?<=Híd neve: )\w.*")
What version of python are you running, this may also make a difference? Your original code works for me with 3.5+ but requires the above change to work with 2.7 (deprecated)
