Search and remove part string with variable content
  • Nov 19, 2014 12:33 PM UTC
  • 7 replies
  • 225 views
bubblebeb
I have a spreadsheet with lines of names and addresses which have comments by the author in square brackets in the names. e.g. Eon Energy [formerly Powergen].
I want to be able to search for and remove everything in the square brackets (and the brackets themselves).
Does anyone know how to do this?
  • Nov 19, 2014 12:57 PM UTC
The StringReplacer and a regular expression might help you.
Text to Match: \\[.*\\]
Replacement Text: <leave blank>
Use Regular Expressions: yes
Takashi
bubblebeb
  • Nov 19, 2014 2:07 PM UTC
Many thanks Takashi
Worked a treat.
bubblebeb
  • Nov 21, 2014 1:39 PM UTC
Takashi
I have found a glitch with the original data where there can be two sets of [ ] in the string. This RegEx removes both sets and everthing in between.
Is there a way of changing the RegEx to remove everything in the [xxx] and then [yyy] rather than everything from the first open [ and the final ]?
Thanks
Seb
  • Nov 22, 2014 4:48 AM UTC
Yes, there is. Try this expression.
  • Nov 22, 2014 5:09 AM UTC
An strange expression. Perhaps you are getting a little confused?
.* matches with 0 or more any characters.
[^\\[\\]]* matches with 0 or more any characters except [ and ].
[ and ] are special characters to define a character class in regular expressions, so you will have to escape them with a backslash if you use them in an expression as the character itself.
See also here to learn more about regular expressions.
Regular-Expressions.info  (http://www.regular-expressions.info/)
jez
Participant
  • Participant
  • Nov 17, 2017 5:05 PM UTC
Hello Takashi. I have a similar issue to the one you resolved here but in mine the string contains data as formatted as : (77) (53.3) (5.33)
I wish to extract the data into three new attributes where Attribute1 = 77, Attribute2 =53.3 and Attribute3 = 5.33.
To add a level of complexity the number of digits and the place of the decimal point can vary within the rows of data.
Please can you advise (I'm no expert!)
  • Nov 17, 2017 11:51 PM UTC
Hi @jez, I added a comment to this thread.
How to expose the charters held within parentheses
