Scripted Web Connection Parameter
  • Mar 17, 2026 10:38 PM UTC
  • 41 views
sam.delore
Forum|alt.badge.img+3
Hi all,
I regularly setup workspaces with quite a few feature readers & writers that need a lot of parameters changed when moving between environments.
I make use of scripted parameters to make this easy based on an initial Environment selection.
The one parameter I can’t get to update correctly with a scripted parameter is the web connection, does anyone know if this is possible?
nielsgerrits
Forum|alt.badge.img+67
I have done this earlier without issues, just return a text string with the webconnection name, but for server you’ll need the webconnection uploaded. So I have dummy disabled featurereaders with the webconnections in the workspace to force it to upload to server.
