Schema validation between two datasets
  • August 7, 2017
  • 6 replies
  • 586 views
pinkopo
Forum|alt.badge.img+5
Hi guys,
I am trying to find a way to get a list of matched and unmatched fields between two datasets.
The situation is our agency needs to reguarly download data from external sources and after download we need to check if there is any schema changes on the newly downloaded data.
Thank you!
Best answer by stalknecht
Hello @sangli,
You can read the schema's and use a changeDetector.
Follow the next link for some examples.
https://knowledge.safe.com/questions/1936/compare-2-schemas-get-list-of-new-attributes.html
Best regards,
Wilko Stalknecht
trentatsafe
Forum|alt.badge.img+7
  • August 7, 2017
Hello @sangli,
This previous question may help answer your question. I believe it is a similar scenario that was asked.
https://knowledge.safe.com/questions/22533/how-to-detect-a-schema-difference-dataset1-has-x-a.html
stalknecht
Forum|alt.badge.img+22
  • August 7, 2017
Hello @sangli,
Best regards,
Wilko Stalknecht
pinkopo
  • August 16, 2017
Hello @sangli,
Thanks @trentatsafe
Both of the datasets that i want to compare are saved in file geodatabase, is there anyway the schema (any format) can read feature class from file geodatabase?
thanks!
  • August 16, 2017
Thanks @trentatsafe
thanks!
No problem. You can just enter manually the *.gdb path to the Dataset field of the Add Reader dialog.
Or, drag and drop the *.gdb folder from Windows Explorer onto FME Workbench Canvas. The Add Reader dialog will open automatically with the *.gdb path. You can then change the Format field to the Schema (Any Format).
pinkopo
  • August 16, 2017
Thanks guys!
pinkopo
  • August 16, 2017
Great thank you takashi san you are the best! ^.^
