Scaler tree model
  • Nov 14, 2018 3:05 PM UTC
  • 5 replies
  • 104 views
I have a problem and it looks fine until I add the scaler. I can´t get the result good with the scaler. I scaled the orginal model to the size of one meter, so the scale factor is right, e.g. a tree with the height 8 meters should have scale factor 8. Why inspector showing strange geometries when I add scale or z in the scale parameters?
IInspector_point.zip have this shapefile also
gio
Forum|alt.badge.img+15
  • Nov 14, 2018 3:28 PM UTC
@tobiasrydlinge1
Have you set it to scale from center? (scale Origin)
Can't load your fmw, get an error.
Seems to work for me..
mark2atsafe
Forum|alt.badge.img+59
What's your coordinate system? If it's lat/long you may have to set the scale in decimal degrees (or temporarily reproject to a coordinate system with metre units to scale in metres)
mark2atsafe
If you can attach the skp file too, then we can run the workspace for real.
Hi!
Thank for your input @gio, @Mark2AtSafe. I changed a few things in my script and now I get the model right. My final fme script looks like this.And the final result
