SBS-Plugin: how to make a new Smallworld datastore visible in the SBS reader table list?
  • Aug 31, 2023 5:35 AM UTC
  • 160 views
femo
I am using the SBS-Plugin for Smallworld to connect to Smallworld datastores. The plugin version is 2021,FME version 2021, the Smallworld version we are using is 5.2.3. We have connected a new datastore to Smallworld. Unfortunately this new datastore does not appear in the table list dialog of the SBS-reader. Any ideas?
kailinatsafe
Forum|alt.badge.img+24
Hello there @femo​, thanks for posting! Have you had a chance to review the Configuration Options Article on the Knowledge Base? When you try to load the table list on the Reader, do any error messages pop up or is the table list simply blank?
If you're still not having luck seeing contents in the table list dialog, I might suggest you submit a support case so we can take a closer look at what's going on. When submitting the support case, please provide all version numbers of applications involved, logfiles and or copies of error messages. Note - it may be possible you'll need to reach out to SBS directly, but we can determine this via case. Happy to help, Kailin.
