Saving spatial index into file problem...?
  • Apr 16, 2019 10:45 AM UTC
  • 76 views
Hi, my fme script, which i have runed for several times stuck, saving index. Can someone explain me the log, to fix the problem. All other proceses runed ok.
  • Apr 16, 2019 11:14 AM UTC
Have you verified that you have enough free disk space on C:?
  • Apr 16, 2019 11:58 AM UTC
I have over 100 gb free on C, and no writers are navigated to that map that spatial index is beeing saved, that is what is strange to me. I am using FME Data interoperability - incorporated into ESRI GIS.
  • Apr 16, 2019 12:01 PM UTC
I agree, that is strange. Try rebooting your PC, if that doesn't work you should consider contacting your FME reseller or Safe support.
  • Apr 16, 2019 12:04 PM UTC
Thanks, Ill run it again and left overnight.
