Saving images from data inspectors
  • Apr 8, 2025 5:02 PM UTC
  • 129 views
armando_amador
Forum|alt.badge.img+5
Is it possible to save the frame of the data inspectors?
I mean, I have this:
Two layers overlapped
Is it possible to save this image at certain zoom directly in FME from data inspector or the regular translation environment?
crutledge
Forum|alt.badge.img+55
  • Apr 9, 2025 1:55 AM UTC
Hi ​@armando_amador If you are looking to create an output of data from multiple sources or layers you could add the ImageRasterizer or MapnikRasterizer to your workflow. There are some great walkthroughs in the links below. Hope that helps!
Converting Vector Data to Raster – FME Support Center
Introduction to the MapnikRasterizer – FME Support Center
max_h
Forum|alt.badge.img+39
  • Apr 9, 2025 1:53 PM UTC
FME Inspector got a ‘save as’-option where you can choose pdf to save your graphic.
But I believe you can’t set your zoom level or choose extends…
So the better way is to crop your data beforehand and then save it as pdf/png/whatever suits your best in your workspace like ​@crutledge explained
