S57 customized files location
  • Aug 2, 2019 10:10 AM UTC
  • 0 replies
  • 43 views
lefred06
Forum|alt.badge.img+10
One of our customers has customized the S57 Reader as explained in https://knowledge.safe.com/articles/570/s-57-enc-hydrographic-data-format.html.
He is concerned by the fact that all customized files are replaced whenever a new FME version is installed, or that the customization should be done again if a new FME version is installed at another location on disk.
This might be acceptable for one user, but this causes much more trouble as the customization has to be performed on all workstations used in the company.
I suggested having FME (or the GDAL S57 format used ultimately) check some location (for example in FME shared directories) for a customization of the format and @danatsafe has filed the FMEENGINE-61034 change request.
Anybody who finds this is a good idea, please vote or suggest any other improvement to the S57 customization process. Thanks.
Fred
