Run multiple FMW files after each other
  • Mar 20, 2025 1:16 PM UTC
  • 112 views
kelin84
I’ve read a couple of posts on this, but I’m still not perfectly sure on how this works.
I have over almost a year been working on and refining a flow. Since I keep getting new updates from the project, the flows has became large. It became into 3 flows, that could maybe have become 1, but I don’t think it would be that easy, at least I’m not up for that task.
It consist of multiple feature readers and multiple feature writers. Each flow takes up some data from the other. For example something can have been made in a file Geodatabase or on ArcGIS Online, and the next flow would then use that content.
So, I easily enough just want to run those 3 flows, by one click in workbench. I would expect just to create something like this. I just find it’s strange to connect it like that.
Is it that easy?
Forum|alt.badge.img+63
Yes 😁
Right now, WorkspaceRunners 2 and 3 only run if the preceding one has been run succesfully, that may be exactly what you want, but maybe you want to consider what should happen if one of them fails.
dustin
Forum|alt.badge.img+36
  • Mar 20, 2025 2:42 PM UTC
I employ this methodology all the time. Yes, it can be that simple. 😁
kelin84
  • Mar 20, 2025 5:56 PM UTC
Thanks guys 😊 then I just leave it as it is.
Yes, I want it to stop if it fails, since it will do more harm than good if it doesn't stop.
