Rule based selection of tables in FeatureReader?
  • Apr 28, 2023 8:55 AM UTC
  • 65 views
aron
Forum|alt.badge.img+16
I would like to select only tables with certain strings in their table names when running a FeatureReader. So something akin to:
WHERE TABLE_NAME LIKE '%searchstring%'
Is this doable? And if so, how?
  • Apr 28, 2023 9:32 AM UTC
You can insert an SQLExecutor before the FeatureReader to query the database metadata tables. This depends on the database implementation, but for SQL Server it might look like this:
SELECT TABLE_NAME
FROM INFORMATION_SCHEMA.TABLES
WHERE TABLE_TYPE = 'BASE TABLE'
AND TABLE_CATALOG='MySchema'
AND TABLE_NAME LIKE '%searchstring%'
You could then pass the resulting attribute TABLE_NAME to the FeatureReader.
aron
  • Apr 28, 2023 3:20 PM UTC
Thanks!
And should anyone ever need to do this treatment on a geopackage file the syntax is:
SELECT TABLE_NAME
FROM GPKG_CONTENTS
WHERE TABLE_NAME LIKE '%yoursearchstring%'
One also needs to repeat the above in the 'attributes to expose field' to give the FeatureReader something to chew on.
  • Apr 28, 2023 3:24 PM UTC
Alternatively, you can also use a FeatureReader set only to read the schema features (i.e. no data features), that way you'll get one feature per table / feature class in the source dataset, which you can then filter using a Tester/TestFilter before sending to the second FeatureReader.
