Rounding attribute value up to closest 100?
  • May 9, 2014 8:43 AM UTC
  • 8 replies
  • 503 views
Does anyone know how to round an attribute value up to nearest 100 ? For example if I have a value 1367 I want it to be rounded to 1400. And if I have a value of 1305 I also want it to bo rounded to 1400. I tried the AttributRounder, but it seems to only round decimal values.
//Eva
  • May 9, 2014 9:29 AM UTC
Hi Eva,
Try this expression with the ExpressionEvaluator.
@ceil(@Value(attribute_name)*0.01)*100
See the help on the ExpressionEvaluator to learn more about @ceil function.
Takashi
  • May 9, 2014 11:46 AM UTC
Hi Eva,
The AttributeRounder works fine, if you write -2 for Decimal Places.
Thomas
gio
Forum|alt.badge.img+15
  • May 9, 2014 11:49 AM UTC
or
(@round((@Value(Nr_to_R)+100)/100))*100
  • May 9, 2014 12:00 PM UTC
I didn't know a negative value can be used for Decimal Places of the AttributeRounder. It's simple and works fine. Thanks for sharing the tips, Thomas!
gio
  • May 9, 2014 12:15 PM UTC
Tho u can use positive or negative rdecimals in the rounder, it has less degrees of freedom.
So if u would want ot round to say 200 or 2, or even better yet 3 (no multiplication by 10 possible now..;) it would be of no use.
(@round((@Value(Nr_to_R)+100)/100))*100 gives full freedom, u can parameterise the values.
  • May 10, 2014 1:04 PM UTC
Gio, does the expression always work as your expecting?
1400 --> ?
1350.0 --> ?
  • May 12, 2014 5:17 AM UTC
thank you all for the solutions, it's working now!
gio
  • May 12, 2014 9:48 AM UTC
...ok....that would be (@round((@Value(Nr_to_R)+99)/100))*100
