Round M coordinate value (linear referencing)
  • September 24, 2018
  • 12 views
I work with geometries (routes) whose vertices have 4 dimensions: XYZ and M (measures). How can I round M coordinate values stored in the data to a specified number of decimal places? The coordinate rounder only covers XYZ dimensions.
I think you'll need to extract the measures into a list, round the values in the list (preferrably using Python, to avoid exploding the list), then assign them to the line again.
fmelizard
Forum|alt.badge.img+19
Hi @hedigerm It sounds like the CoordinateRounder should be able to handle measures too. Can you post this idea at https://knowledge.safe.com/content/idea/list.html ?
  • September 25, 2018
https://knowledge.safe.com/idea/79203/enable-coordinaterounder-transformer-to-round-meas.html?
