retrieve value
  • Sep 3, 2025 3:10 PM UTC
  • 56 views
marionmahot
Forum|alt.badge.img+4
Hello
In one tester I enter a value through a published parameter. Then I have a second tester in which I would like to retrieve the previously entered value. How can I do this?
Thanks
hkingsbury
Forum|alt.badge.img+73
  • Sep 3, 2025 8:16 PM UTC
You can select the parameter to be used as part of the test clause from the drop down menu in the tester
You can also use the ParameterFetcher to ‘fetch’ the parameter value to an attribute
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Transformers/Transformers/parameterfetcher.htm
