Replacing faulty Z coordinates in an easy manner ?
lifalin2016
Forum|alt.badge.img+29
Hi all.
I'm just being told, that we're importing 3D data (points, lines, polygons) with "missing" Z coordinates = 0.
I need to delete each and every one of these values, or exchange them with the value -99.
Is there a transformer that can do that easily ?
I would rather not have to to explode all geometries to points, repair the Z, and reassemble all geometries.
Any ideas ?
Cheers
Best answer by ebygomm
lifalin2016 wrote:
Alas, GeometryReplacer reintroduces a faulty Z in geometries, that feature mixed-Z nodes.
This line string (in WKT): LINESTRING (571385.6196 6138491.615,571392.3857 6138491.1588 109.433,571398.7318 6138488.917 109.209)
has one node without a Z, and two nodes with a Z.
After using GeometryReplacer on it the geometry looks like this:
billedeand exports to GeoJSON like this:
{"type":"LineString","coordinates":[[571385.6196,6138491.615,0],[571392.3857,6138491.1588,109.433],[571398.7318,6138488.917,109.209]]}
Ah well, back to the drawing board :-(
Ps!
MS/SQL do respect mixed-Z geometries. Here's the result of [geom].AsTextZM():
LINESTRING (571385.6196 6138491.615, 571392.3857 6138491.1588 109.433, 571398.7318 6138488.917 109.209)
This syntax in WKT will create a geometry with a missing z value using the geometry replacer
LINESTRING (571385.6196 6138491.615 -nan,571392.3857 6138491.1588 109.433,571398.7318 6138488.917 109.209)
The geometry then when written to MS SQL with an FME writer will be written without the z value and return the following with your geom.AsTextZM() statement
Still going to be an issue with GeoJSON but will then return null which should be easy enough to strip out
I was surprised to learn that
{"type":"LineString","coordinates":[[571385.6196,6138491.615],[571392.3857,6138491.1588,109.433],[571398.7318,6138488.917,109.209]]}
appears to be valid geoJSON
geomancer
Forum|alt.badge.img+50
  • March 23, 2023
There are some interesting ideas here. The first one includes python code, the second one uses only FME transformers. As you only want to replace 0 values, you can simplify both solutions.
Replace_Z_0Note the commas in Text To Replace and Replacement Text (you don't want to replace 10).
Also make sure the incoming features are 3D, otherwise you may inadvertently replace a vertex's y-value.
lifalin2016
  • March 28, 2023
I have been looking into something similar, although I looked at WKT. In WKT I can use " 0)" and " 0," (first character is space) to find zero-Z's. GeoJSON may simplify that a bit.
Yes, forced 3D is essential to not accidentally remove a Y value of 0.
lifalin2016
  • March 28, 2023
Ps!
lifalin2016
  • March 28, 2023
So I've built a small test workspace, extracting all geometries and IDs, exporting ther geometries to WKT, removing all Z=0 references, and updating the geometries in my MS/SQL using SQLExecutor and a command along this line:
UPDATE @Value(fme_feature_type) SET [geometri] = geometry::STGeomFromText('@Value(_geometry)',25832WHERE [ID] = @Value(ID)
I know for a fact, because I've tested it, that this should respect missing Z's in line/polygon geometries, that do have other Z values. The downside is that it's an extremely slow method. Something like 10 geometries per second, and I have more than 600K+ to process !
GeometryReplacer cannot be trusted, as it inserts dummy Z values if other Z values are present, so I cannot use writers to update my geometries.
Using PythonCaller to utilize feature functions getAllCoordinates, resetCoords, and addCoordinates unfortuately results in the same inserts of dummy Z values.
Forum|alt.badge.img+39
  • March 28, 2023
Can you not do your update via a single SQLExecutor statement for the entire table rather than on a line by line basis?
Out of interest, do these geometries evaluate as true with STIsValid() ?
  • March 28, 2023
Ps!
geomancer
  • March 29, 2023
Can you use SQL To Run After Write (Parameters, Advanced)?
lifalin2016
  • March 30, 2023
No, I cannot use a single UPDATE statement, as @(fme_feature_type) is highly variable.
But I did manage to use a writer instead in update-mode, and that gave me much better performance.
The geometries are fairly simple, so it's not a case of invalidity.
lifalin2016
  • March 30, 2023
I'm not sure what you mean by this.
geomancer
  • March 30, 2023
You can write GML (or GeoJSON, or WKT, or something else) to a column in your database, and afterwards let the database translate this value to geometry. You can do this by passing SQL commands to the database in 'SQL To Run After Write' in your Writer or FeatureWriter.
A few years ago I described a possible process for Oracle Non-Spatial in this post.
lifalin2016
  • March 31, 2023
That kinda defeats the whole purpose of using FME, doesn't it ? I was looking for a way to use FME to have it run as a post-processing task, after FME is used to import new data. Using FME to just run T-SQL isn't very productive, imho, unless it's absolutely necessary. I'm using writer "before" and "after" SQL to truncate tables before import, and run MakeValid on data after import. But in this case it makes little sense to go that way. Sorry.
Besides, the before/after scripts are completely static, and doesn't allow anything but simple text substitutions.
lifalin2016
  • March 31, 2023
I did manage to switch to a writer in update-mode, which increased the performance significantly :-)
lifalin2016
  • May 10, 2023
Ps!
Hi ebygomm. I did end up going with WKT-replacement in the database, and opted out of having mixed Z-presence in multi-node geometries (using the system defined "null" value of -99 in this case). But using "-nan" is an interesting option, so I'm giving you the "best answer" in case others need this in their projects.
