Replace point with symbol in workbench (is it possible within FME)
  • Nov 6, 2025 10:51 AM UTC
  • 72 views
jopie
Participant
Forum|alt.badge.img+3
Hello,
Created a nice workbench with FMe. However, there are also many individual points in the data, which are poorly visible.
Which transformer can you use to replace a point in the data with a symbol (e.g., a circle with a specific diameter)?
This improves clarity and better visualization in the final result.
Forum|alt.badge.img+63
You can use a 2DEllipseReplacer to create a circle with a set diameter (well, technically an ellipse but if you set the primary and secondary axes to the same length it’ll be a circle) and then a FeatureColorSetter to specify a color (set it to fixed scheme so you can specify pen and fill color).
