Rename attribute name from repeating attribute values
  • Mar 13, 2023 1:19 AM UTC
  • 75 views
I apologize if this has been asked before but I couldn't find anything related.
I have a csv with the following data:
1With no header names. And I'm trying to get the following:
2I'm not sure which transformer to use, I thought BulkAttributeRenamer could help me here but I can't manage to make it work.
I appreciate all your help before hand.
hkingsbury
Forum|alt.badge.img+73
  • Mar 13, 2023 2:58 AM UTC
When you add the csv reader, make sure you Field Names Lines is empty, and your Data Start Line is 1
The attribute names will then come through as col0, col1, col2 etc.
You can then rename these user the attributeRenamer or the attributeManager
  • Mar 13, 2023 3:24 AM UTC
Yeah the problem is that I got tables with up to 100 attributes so I was looking for a solution to not doing manually.
Thank you!
Forum|alt.badge.img+54
  • Mar 13, 2023 9:23 AM UTC
One possible way, you would need to Expose the newly created Attributes but that can be done fairly quickly by importing from FeatureCache
