Removing the “overlap” (duplicates) with the option (create new feature),
  • Mar 28, 2014 6:34 AM UTC
  • 122 views
jamal
Forum|alt.badge.img+5
I have two hatches that are overlapped. I wanted to convert them to areas and then to eleminte the overlap by adding new feature for the overlapped area (as we do in the topology of the ArcGIS).
How this might be accomplished in the FME?
CAD File:
http://www.mediafire.com/download/rt7sfabb9whzzi4/Overlay.dwg
Thank you
Best
Jamal
  • Mar 28, 2014 7:30 AM UTC
you can use the AreaOnAreaOverlayer, check the "_overlaps" count attribute to filter out the overlapping parts.
David
jamal
  • Mar 28, 2014 8:22 AM UTC
Thank you for the help David. It works fine.
Best
Jamal
