Removing Items from after successful test
  • Jun 26, 2019 5:28 AM UTC
  • 101 views
deanhowell
Forum|alt.badge.img+24
Hello all,
I have a DWG file that has distance labels (text) and lines that I need to attach the text to.
I have figured out, mostly through assistance through this forum (thank you), how to get the closest features to match but what I am having trouble with is where the text label is not the closest feature.
I have used the Neighbor Finder and then a feature merger but for the ones that don't merge I want to be able to do a second test to look through the list of the other lines that are in the closest lines list.
I have done this by using a List Exploder, followed by a length calculator and then a tester. My issue is that if I have found the closest 5 features to the label and the test is successful on one of them, how do I ignore the other four in the test? In some cases no matches will be found, so in this case I need to keep the failed record.
Any assistance or guidance into how to do this better is very much appreciated.
Thanks
Dean
Forum|alt.badge.img+54
  • Jun 26, 2019 7:42 AM UTC
What is your test? Is it something that can be done without exploding the list?
deanhowell
  • Jun 26, 2019 10:04 AM UTC
Thanks @egomm I am trying to test the length of the closest 5 lines to see which one matches the text label. The neighbors finder gives me the list but it is not always the closest label.
  • Jun 26, 2019 10:37 AM UTC
I was thinking an option might be to add the length to the list created in the neighbourfinder then using a listsearcher to find the match.
deanhowell
  • Jun 26, 2019 11:14 PM UTC
Thanks @egomm, yes that did the trick, although it did introduce an issue around string comparison as 11.7 is not the same as 11.70, so might need to do some pre-work on the values before testing. The upside it brought the test down from six transformers to two :)
