Removing empty spaces and formatting data from rows to columns
  • October 6, 2016
  • 57 views
gisgeek
Forum|alt.badge.img+9
I have data in the the following format I want to get from rows to columns so that the rows are displayed as columns like this. Hoping someone can help me with this.
FID Loc_name Status
35 NZL.PointAddress M
NZL.PointAddress FID 35 Loc_name NZL.PointAddress Status M Score 100 Match_type A Match_addr 40 Maui St, Pukete, Hamilton, 3200 Addr_type PointAddress Type PlaceName Place_addr Phone URL Rank AddBldg AddNum 40
  • October 7, 2016
Hi @gisgeek, summary of a possible way is:
  1. Translate the data to a set of features each of which has an attribute representing a pair of a desired column name and corresponding value. e.g. 1st feature has an attribute called "FID" which stores "35"; 2nd feature has an attribute called "Loc_name" which stores "NZL.PointAddress"; and so on.
  2. Aggregate all the features into a single feature, with the Aggregator (Accumulation Mode: Merge Incoming Attributes).
  3. Expose the column names ("FID", "Loc_name", etc.), with the AttributeExposer.
The concrete method for the step 1 may vary depending on how the source data would be supplied.
  • October 11, 2016
@gisgeek I think if we'll be able to offer more help if you can define the structure of your data a little more clearly. How do you identify a new record? It looks like AddBldg is an attribute name, so is that value <null>? Are the number of attributes predicatable?
  • October 11, 2016
Assuming that the data repeats in a consistent way, you can use a combination of the ModuloCounter and the AttributeCreator with the Enable Adjacent Feature Attributes option to create the name/value pairs and then aggregate those to create a single feature. See the attached workspacerows-to-columns.fmwt
