Removing Bridges between Polygons
  • August 15, 2019
  • 24 views
Hi all,
I have just been clipping some datasets in FME and I have noticed that it has left some sliver bridges connecting polygons. Is there a way to remove them?
I tried using a snapper with various tolerances and using the sliver remover.
Attached is a polygon with one of the bridges
Thanks
FME 2019.1.0.0
  • August 15, 2019
Hi @mattenvsys, this workflow might help you.
  1. Chopper (Mode: By Vertex, Maximum Vertices: 2): Split boundary of the polygon into individual segments.
  2. Intersector or LineOnLineOverlayre (Tolerance: 1e-2): Insert vertices into the ends of the "bridge".
  3. AreaBuilder: Create polygons from the intersected lines.
Appropriate tolerance depends on the actual data conditions. 1e-2 worked for the sample data you posted, but may not work for other polygons.
