remove last 3 numbers
  • Apr 14, 2020 12:46 PM UTC
  • 8 replies
  • 964 views
terezia86
HI everyone,
I would like to remove last 3 numbers from a value. For example 010003000 to > 010003... or 123456789 > 123456 (not all values are ending with 0)
so I do need some general formel for this.
any tips?
Thanks
Best answer by ebygomm
You can use a substring extractor with the following settings
  • Apr 14, 2020 12:57 PM UTC
There are several ways, but the simplest is probably to use the SubstringExtractor:
Negative index values are counted from the end of the string.
Forum|alt.badge.img+54
  • Apr 14, 2020 12:58 PM UTC
danilo_fme
Forum|alt.badge.img+58
  • Apr 14, 2020 12:59 PM UTC
Well done!
  • Apr 14, 2020 1:01 PM UTC
Hi @terezia86, you can use the StringLengthCalculator to get the length (number of characters) of the value and extract desired substring with the SubstringExtrator, as in.
Just be aware that the index representing position of a character starts with 0, so you need to subtract 4 (not 3) from the total length.
terezia86
Perfect!
THANKS!
  • Apr 14, 2020 1:03 PM UTC
Ah yes, the index can be a negative number...
  • Apr 14, 2020 1:08 PM UTC
It's a pity you can't use the negative numbers like that in an @Substring expression
  • Apr 14, 2020 1:16 PM UTC
Not a big deal, though...
@Left(@Value(text),@StringLength(@Value(text))-3)
