Remove extra vertices and retain geometry (Line)
  • Mar 6, 2025 7:11 PM UTC
  • 218 views
galigis
Forum|alt.badge.img+22
Hi All,
I’m trying to create a 10m node line from a 2.5m node line. I have tried ‘Densifier’, ‘Line Combiner’ and also ‘Chopper’ but can’t get it to work,
How can I reduce the number of vertices and to obtain a 10m node line?
Thanks
Best answer by nielsgerrits
  • Densifier 10 meter.
  • Chopper 10 meter.
  • Generalizer to remove all points except start & end.
  • LineCombiner to reconnect all lines.
nielsgerrits
Forum|alt.badge.img+67
  • Chopper 10 meter.
galigis
  • Mar 10, 2025 9:35 AM UTC
Thanks ​@nielsgerrits  - your suggestion has worked perfectly :)
Below an screenshot of the workflow for completeness:
