Remove duplicates within a subset of data
ngstoke
I'm attempting to remove duplicate values, but only if they are within a subset of my data:
Is there a way to remove the duplicate 'Lease Number' within each unique 'Unit Name' ?
Best answer by gio
you can also create a list grouped by both columnnames, and then use a listindexer or histogrammer etc..
Or use a Matcher non geometric, then you can use bot attributes to find the uniques.
erik_jan
Forum|alt.badge.img+26
  • March 8, 2016
The DuplicateRemover transformer can be used on multiple attributes. The Unique output port will generate what you need.
ngstoke
  • March 8, 2016
Hi erik_jan,
I've tried the transformer you suggested, in different combinations am I missing something? The only output in all these combinations is '1 Alpha'
gio
Forum|alt.badge.img+15
  • March 8, 2016
erik_jan
  • March 8, 2016
Hi erik_jan,
You want one DuplicateRemover with both attributes selected:
ngstoke
  • March 8, 2016
That worked! Thanks for the help.
