Remove duplicate features based on geometry
  • May 31, 2022 10:20 AM UTC
  • 3443 views
marcusth
I would like to remove duplicate features based on geometry. It's a dynamic workbench where i query out all tables which intersect with a polygon.
The problem is that our database contains some duplicated features. For example 1 layer for the whole country, and 1 where it's only a small part of it. So i just want one of these.
I have tried to use this guide. But the problem is that the geometry is not 100% alike. So the CRCCalculator gives different values. The coordinates are more exact in one of them.
Any tip on how i could fix this?
Here is an example of how the difference is for the same point:
Min_max_extents
Best answer by ebygomm
Have you looked at the matcher? That will let you find geometries that match and allows lenient matching and lets you set a tolerance which should handle the slight differences in precision.
Forum|alt.badge.img+54
  • May 31, 2022 11:02 AM UTC
dustin
Forum|alt.badge.img+36
You could try using the Dissolver transformer with the Group By option set to the country identifier.
marcusth
  • May 31, 2022 11:21 AM UTC
Yeah i had tried it, but somehow managed to miss the "Vector Tolerance" field! Thanks! 😁
marcusth
  • May 31, 2022 11:34 AM UTC
Thanks for the reply. The previous answer solved my problem in this case.
