Remove decimal and decimal values without rounding.
  • March 3, 2017
  • 6 replies
  • 309 views
katericondo
Forum|alt.badge.img+8
Say I have 105.6546 and 5646.546356, how can I drop only the decimal and values to the right of the decimal? So my final values will be 105 and 5646.
Best answer by jdh
Using the arithmetic editor in any of the transformers that create attributes, you can use @int() or @floor().
@int will truncate the value, @floor will return the next lowest integer, these are identical for positive values, but will differ by 1 for negative values.
@int(10.1) =>10
@floor(10.1) =>10
@int(-10.1) => -10
@floor(-10.1) => -11
erik_jan
Forum|alt.badge.img+26
  • March 3, 2017
The ExpressionEvaluator transformer can be used, using the floor function. It will be in the Math section.
katericondo
  • March 3, 2017
Hi Erik_jan, it created a new field but all values were null.
jdh
Forum|alt.badge.img+41
  • March 3, 2017
@int(10.1) =>10
@floor(10.1) =>10
@int(-10.1) => -10
erik_jan
  • March 3, 2017
You have to set the ExpressionEvaluator to overwrite existing attribue:
To get this result:
itay
Forum|alt.badge.img+19
  • March 3, 2017
I would use the AttributeSplitter and use the first element of the lists.
  • April 15, 2017
For what it's worth, if the @floor function satisfies your requirement, the AttributeRounder (Decimal Places: 0, Round-off Direction: Down) can also be used. Instead of the @int function, the StringReplacer with this setting works for you.
  • Mode: Regular Expression Replace
  • Text to Replace: (.+)\\..*
  • Replacement Text: \\1
