Remove attribute data type/encoding
  • October 13, 2015
  • 6 views
I received an FFS file and most of the attributes have their data types/encoding as suffix in the attribute name field (see embedded image). How can this be turned off or removed?
Best answer by takashi
The AttributeRenamer and/or AttributeRemover can be used to rename and/or remove the attributes. If the attribute names are not displayed in the Workbench interface, you can expose them by checking "Exposed" checkbox in the reader feature type properties dialog, or using the AttributeExposer.
Takashi
  • October 14, 2015
Takashi
