Rejected Feature Handling on FME Server
  • Mar 5, 2018 6:33 PM UTC
  • 5 replies
  • 295 views
I am noticing that even if I set my workspace in Workbench to terminate on rejected features, it runs without error on FME Server. Is the rejected feature handling a workbench-only feature? I am expecting to see the same behavior on FME Server. I'm using 2017.1 in my testing. Thanks.
Best answer by brianatsafe
Happy to announce that this issue has been fixed and will be available in FME 2018.1.
fmelizard
Forum|alt.badge.img+22
  • Mar 5, 2018 7:03 PM UTC
Hi @dbaldacchino,
It should be the same as whats set in the workspace. Can I ask which transformer(s) you are seeing the wrong behaviour in?
Hi @MattAtSafe,
I'm using an HTTPcaller. The workspace terminates in workbench but not on FME Server (I have to add a terminator to get the expected behavior on FME Server).
fmelizard
  • Mar 5, 2018 7:27 PM UTC
Hi @MattAtSafe,
Hi @dbaldacchino,
Thanks I've taken a look into the system and it seem like this is a know issue for the HTTPCaller (and some JSON transformers). I have linked this Question to the internal prblem report. Thanks for sharing your worksaounrd and I'm sorry for the inconvenience this bug may have caused.
Hi @dbaldacchino,
Thanks for confirming @MattAtSafe, very much appreciated!
brianatsafe
Forum|alt.badge.img+13
  • Jun 29, 2018 9:23 PM UTC
