Regex replace multiple consecutive string occurrence with single instance or the same string
  • April 4, 2017
  • 7 replies
  • 518 views
(I am using FME Desktop 2015.1)
Can anyone help with the regex needed to replace multiple consecutive occurrences of a flag which I have created with a single instance; the flag may appear as a multiple occurrence at many positions throughout the text. Each time I need to replace the many instances with a single instance. Please see examples below.
Please note that as in the first flag grouping in example 1 it may or may not have spaces either side of the grouping. At present the 'flag' is (TMP_flag) but if this syntax (namely the parenthesis) cause an issue I can change them.
Example 1
I am text before(TMP_flag)(TMP_flag)I am text in the middle (TMP_flag)(TMP_flag)(TMP_flag) I am text at the end(TMP_flag)
Becomes
I am text before(TMP_flag)I am text in the middle (TMP_flag) I am text at the end(TMP_flag)
Example 2
(TMP_flag)
Becomes
(TMP_flag)
Example 3
Becomes
(TMP_flag)
Example 4
Some more text(TMP_flag)(TMP_flag)
Becomes
Thanks in advance,
Rob
Best answer by takashi
Hi @rob14, the StringReplacer with this setting might help you.
  • Text to Match: (\\(TMP_flag\\))+
  • Replacement Text :\\1
  • Use Regular Expressions: yes
  • April 4, 2017
  • April 4, 2017
Hi @takashi,
Thanks very much, that has worked a treat.
(As an aside I had already used one of your previous posted answers to remove multiple consectutive spaces \\s{2,}. I had tried to tweak this to remove the flags but had not managed it.)
Thanks again,
Rob
gio
Forum|alt.badge.img+15
  • April 4, 2017
U can do that using regsub in a (for instance) attribute creator using the Arithmitic editor.
[regsub -all -line {(\\(TMP_flag\\))\\1*} )} {\\1}]
test is the attribute I used to hold your examples.
nd
  1. I capture (TMP_flag) by regexp (\\(TMP_flag\\)) whereby enclosing braces are escaped \\( and \\) and the outer braces define the capture group.
  2. The curly braces are needed because your string contain spaces, braces and underlines (double quotes will yield a error)
  3. the \\1 denotes the (first) capture group. Needs to be in curly braces because of the braces in the capture group.
  4. switch "-all" finds all matches and "-line" to do it till end of line.
Stringreplacer transformer can alos be used:
Text to match: (\\(TMP_flag\\))\\1*
Replacement text : \\1
Use regular expressions: Yes
For explanation see
https://www.tcl.tk/man/tcl8.4/TclCmd/regsub.htm
A must to have in your favorites list.
gio
  • April 4, 2017
lol...I took too much time typing.
  • April 4, 2017
Hi @gio
Thanks for the answers and the explanation of the regex processing.
I need to spend more time on understanding how it works as it is very powerful, when you know what you are doing. :-)
Rob
Hi @gio
Thanks for the answers and the accompanying explanation as to the Regex processing.
I need to spend more time learning/working with this to develop my skills, it is a really powerful tool when you know what you are doing. :-) (one day hopefully)
Rob
  • April 4, 2017
Hi @gio
I had problems with double posting now!
gio
  • April 4, 2017
..I am honored ;)
