Reducing Polygon area by set percentage / Keeping the shape of it but now with a smaller view and area.
  • Jun 9, 2023 12:42 AM UTC
  • 197 views
I have a polygon (shp or minfo format) assuming it has an area of 5 square miles. Need to reduce the area by 70% resulting to 3.5 square miles now but still keeping somewhat the outline but of a smaller size (like polygon output shrinks) due to the applied percentage. SCALER transformer is closed to what I need but it only applies the percentage to the total perimeter of the polygon and not the area. Any transformer that could do this?
geomancer
Forum|alt.badge.img+69
  • Jun 9, 2023 7:45 AM UTC
Set the square root of 0.7 as the Scale Factor in the Scaler.
@sqrt(0.7)
Scale_Factor_sqrt
  • Jun 9, 2023 4:55 PM UTC
Thanks for your reply on this. Recommended setting works and have verified the calculated area and retained shape of the polygon (reduced one). Appreciate the help.image
geomancer
  • Jun 12, 2023 6:12 AM UTC
You're welcome, I'm glad I could help you out.
