reduce the Bounding Box Size
boubcher
Forum|alt.badge.img+11
Hello there how could we change the bounding box size as shown bellow
keeping the reduced size in the same place
Thans
nielsgerrits
Forum|alt.badge.img+54
One way to do this:
  • BoundsExtractor to find _xmin, _ymin
  • Offsetter to move to 0,0 using _xmin, _ymin *-1.
  • Scaler to scale down how you need, Scale Origin set to 0,0.
  • Offsetter to move back to original lower left corner using _xmin, _ymin.
Forum|alt.badge.img+39
  • May 30, 2022
Assuming you know the scale factors and by keep in the same place you mean share the same lower left coordinate then this workflow should give you the output you want.
boubcher
  • May 31, 2022
ebygomm & @nielsgerrits Thanks Guys Great Aproch
