Redefine an autocad block.
  • Feb 11, 2019 7:22 PM UTC
  • 82 views
Hi, do you have some tips to redefine a autocad Block? In the original dwg the block (POST) are create on the layer 36. I need to recreate on layer POST. Any Suggestion?
jovitaatsafe
Forum|alt.badge.img+11
Hi @carto30,
Have you tried adding your source dwg file as a template on the writer and writing your block out to the feature type POST? Make sure your writer Layer Definition is set to Copy From Reader and that you specify the Layer Name in the writer feature type parameters.
danilo_fme
Forum|alt.badge.img+58
  • Feb 23, 2019 11:52 PM UTC
Hi @carto30
I agree with @JovitaAtSafe about this Suggestion.
Thanks,
Danilo
