Receive Server Workspace parameters as json
  • May 9, 2018 1:43 PM UTC
  • 8 replies
  • 65 views
dollargis
I have to create a workspace that runs a not-predefined number of copy/conversion jobs and at the end send back a REST-call with a json body to signal success or failure.
The sending party wants to submit a json structure in the form
  portalid = 4711,
  source = 'config',
  target = 'qs',
  tables = [
    'gsm.viertel',
'rgu.abfallanlagen',
'plan.gruen_poly'
  raster = [
'flaechennutzungsplan.tif'
with variable numbers of tables and rasters, and my workspace has to
* receive,
* parse,
* run the tasks
and collect the information on the subprocesses.
While I know how to submit the single jobs through FMEServerJobSubmitter, I have no idea of how to realise especially the receiving part.
When the json request body has arrived in the workspace, I guess the JSONFlattener will be the Transformer to use in order to get at the different parameter, and probably a list exploder to extract the list of tables.
Any support, especially a hint where this is described in the documentation, will be greatly appreciated.
Best answer by takashi
Expose required attribute names including the list names ("po_raster{}" and "po_tables{}") via the Attributes to Expose parameter in the JSONFlattener. You can then assign desired attributes to published parameters of the workspace through the FMEServerJobSubmitter. A list element can be specified with an index - e.g. "po_tables{1}".
dollargis
  • May 9, 2018 2:56 PM UTC
OK - got one step further:
https://knowledge.safe.com/articles/1293/data-loading-with-fme-server.html
seems to cover at least a bigger part of what I need to know
dollargis
  • May 9, 2018 10:18 PM UTC
Ok, some steps further I have this:
Which gets submitted to the server and called through curl with the json data from the opening message. The logger writes those lines in the log:
Attribute(64 bit integer): `po_portalid' has value `4711'
Attribute(encoded: UTF-8)         : `po_raster{0}' has value `flaechennutzungsplan.tif'
Attribute(encoded: UTF-8)         : `po_source' has value `config'
Attribute(encoded: UTF-8)         : `po_tables{0}' has value `gsm.viertel'
Attribute(encoded: UTF-8)         : `po_tables{1}' has value `rgu.abfallanlagen'
Attribute(encoded: UTF-8)         : `po_tables{2}' has value `plan.gruen_poly'
Attribute(encoded: UTF-8)         : `po_target' has value `qs'
Attribute(string)                 : `text_line_data' has value
`{"portalid":4711,"source":"config","target":"qs","tables":["gsm.viertel","rgu.abfallanlagen","plan.gruen_poly"],"raster":["flaechennutzungsplan.tif"]}'
This is correct - there are lists for tables and raster as it was submitted in the json-body of the request.
The point where I am struggling now is how to feed those list values into a  ServerJobSubmitter that will do the processing for each list entry?
  • May 9, 2018 10:28 PM UTC
dollargis
  • May 10, 2018 6:38 AM UTC
Ok, got it that far - your answers confirmed what I had assumed.
receivepost.fmw is the workspace.
The job log shows this:
i.e. the child workspace gets only called once, and unfortunately without set parameter.
I guess its the way I set the parameter in the JobSubmitter - the list doesn't get expanded.
What I need is that the job submitter gets called for every entry in the list. The number of entries can not be defined beforehand, but varies from call to call.
  • May 10, 2018 10:38 AM UTC
If you need to submit the job for each element of the "po_tables{}" list, consider using the ListExploder to explode the feature.
dollargis
  • May 10, 2018 1:59 PM UTC
Yes, @takashi, but how?
The dropdown does not offer 'po_tables' and I did not find a way to enter that into the red text field
  • May 10, 2018 2:32 PM UTC
Please reread my first answer: "Expose required attribute names including the list names ("po_raster{}" and "po_tables{}") via the Attributes to Expose parameter in the JSONFlattener."
dollargis
  • May 10, 2018 2:37 PM UTC
Thanks million, @takashi - I had overlooked those curly braces. Now it seems to work.
