Reading ZIP files in FME server from untrusted source that might contain malware/virus
  • Jun 17, 2019 10:14 AM UTC
  • 9 replies
  • 185 views
oscarwillems
Forum|alt.badge.img+19
Hello,
For a project we are looking into building several workspaces/token-based apps that can be run on FME Server. Due to strict security requirements we have to make sure that either compressed files are rejected or are handled in a safe manner.
As I understood FME 2018 and older decompress the zip file first to a temp folder, then using the extracted files to read the data (into ffs), this potentially exposes the file system to malicious files from the zip.
Upon being read, the data is extracted and used just as if it were a normal dataset. FME is able to read data stored directly in an archive file, or within sub-folders. archive_files_reading.htm
Notable New Features 2019.0
Automatic Decompression
Read your compressed data files directly in FME without having to decompress them first. Another barrier has been taken down!
FME 2019 New Features
Does this expose the content of the zip to the file system? Somehow the files of the zip have to be stored somewhere. EDIT: Yes it still extracts everything to a temp folder including files not in the filter (somearchive.zip\*.xml)
How does FME deal with potentially harmful zip archives? Store it at an intermediate location and run a virus scanner and then use the validated zip?
  • Jun 17, 2019 10:38 AM UTC
You wrote:
FME 2019 decompresses the zip directly to FME's internal ffs format [...]
Have you verified this? It was my understanding that FME would simply unzip the data as-is, without any conversion.
I would not assume that FME does anything at all to detect potentially harmful zip files, as far as I know there are no such mechanisms built into FME Server. My recommendation would be to custom build the zip file deposit functions before passing it on to FME Server.
Operations might include
  • Sanitize zip filename to avoid illegal characters
  • Sanitize/check filenames of zip file contents to avoid illegal characters
  • Check for invalid/malicious zip files
  • Check zip size (to avoid filling disk space, should be done at upload to terminate streaming once size limit has been reached)
  • Verify checksums in zip headers
  • Scan for virus and trojans
Basically, as you mention, allowing "anybody" to upload "anything" is a huge security risk.
oscarwillems
  • Jun 17, 2019 10:42 AM UTC
Notable New FeaturesAutomatic Decompression
  • Jun 17, 2019 10:43 AM UTC
Thanks! That's interesting. But does it really mean that the files are automatically converted to FFS, or are they simply streamed into the regular reader from the zip libraries?
oscarwillems
  • Jun 17, 2019 11:16 AM UTC
I did some testing, and it still extracts everything to a temp folder, albeit briefly (only trackable when running with breakpoints) including my "MaliciousFile.ps1" that I sneaked into my zip.... even with the *.xml filter in the path name (.zip\\*.xml)
So zip file and archive support might be something that was already on 2018 but is now officially in 2019
  • Jun 17, 2019 11:22 AM UTC
Thats very interesting, thanks for testing and sharing your results!
runneals
Forum|alt.badge.img+32
  • Jun 17, 2019 3:35 PM UTC
@rylanatsafe This would be something good to take a look at if you haven't already
rylanatsafe
Forum|alt.badge.img+14
Thank you @runneals for the notification – I had not seen this thread yet.
rylanatsafe
@oscarwillems After reviewing this Q&A posting in its entirety, I think that @david_r provides sound recommendations.
The posting in the "FME 2019 New Features" article is a little ambiguous with its wording... There was no change in functionality for decompressing ZIP files – rather we added additional support for other compression formats (.rar, .tar, .tar.gz, among others).
As observed, FME does extract all contents of the compressed file – and noted that these files are cleaned up after the translation, i.e. only temporarily stored, and they are not manipulated by FME unless configured in the FME Workspace itself.
The filter will not prevent certain files from extracting to your file system, but it will limit what FME reads and will actively perform translations on, such as converting to the internal format FFS.
We do not have plans to implement any virus or security utility with FME Desktop or FME Server for the context of scanning / verifying compressed files used in translations.
If you have any further concerns, please add comment or get in touch with our Support Team.
chk1
Forum|alt.badge.img+7
  • Jul 12, 2019 2:01 PM UTC
Hello David, you mention "Check zip size", checking the contents should be of concern as well. There is a technique called a "zip bomb" (basically, stuffing giant text files into a tiny zip file, some techniques also involve modifying the zip headers to include this file several times). Just something that has been on my mind for a while, not sure if FME (or the underlying libraries) checks for such kind of files.
