Reading/Writing seg-d files
  • Apr 21, 2026 12:03 PM UTC
  • 48 views
karlos
Participant
Does anyone know of a transformer that is able to handle SEG-D files? (not SEG-Y). I want to be able to read in a file, filter for specific channels, then write back a new filtered file to the same directory. I thought it might be possible to run a python script that does something along these lines...so I thought id ask if anyone has done that first before trying to reinvent the wheel!
Thank you,
Regards,
Karl
crystalatsafe
Forum|alt.badge.img+32
Hi ​@karlos
I don't believe there is currently a way to read SEG-D files in FME.
If you would like to, please create an idea on our Ideas Board and let us know what the value of this change would be for you. Hearing about how this affects our customers' workflows and use cases helps our team better prioritize enhancements like these.
