reading shape files goes wrong in FME ?
  • May 7, 2022 10:30 AM UTC
  • 5 replies
  • 166 views
gisgis
Forum|alt.badge.img+4
I have some shape files that might be corrupted i think... However reading/viewing them in ArcGIS Pro is working without any issue whereas in FME it reads them all but it mixes attributes of the features! e.g. Point 1 (shape file feature) becomes attributes from lets say point 10 (another shape file feature) an so on! All attributes are mixed! is this issue known? I am using FME 2022.0 p.s. I am just reading shape files without doing any transformation.
danilo_fme
Forum|alt.badge.img+58
  • May 7, 2022 1:48 PM UTC
Hi @gisgis​
It can be some shapefiles hasn't auxiliar files in the directory ( like shx, prj...).
Please, could you share us the log file?
Thanks in Advance,
Danilo
gisgis
  • May 7, 2022 2:36 PM UTC
Hi @gisgis​
Thanks in Advance,
Danilo
Hi @danilo_fme​
it seems auxiliar files are all there and the only warning I get in the log file is:
"Shapefile Reader: Shape file has more records than .dbf"
DanAtSafe
Forum|alt.badge.img+23
  • May 7, 2022 7:01 PM UTC
Hi @gisgis​ It sounds like some sort of data corruption. If you want to compare the *.shp with the *.dbf you can read a Shape file without the *.dbf and of course you can read the *.dbf with the dBase reader. Please send us your shapefile via https://community.safe.com/s/submit-case if you'd like us to take a closer look.
gisgis
  • May 7, 2022 7:55 PM UTC
Yes I just uploaded my data...
danilo_fme
  • May 10, 2022 9:54 AM UTC
Hi @danilo_fme​
Thanks your answer @gisgis​
