Reading Features with Feature Reader using a list for WHERE Clause
  • Jun 20, 2024 1:38 PM UTC
  • 1179 views
alfons
Forum|alt.badge.img+7
I have two feature classes (FC) that are linked by a 1:1 relationship. Both FCs contain about 4,000,000 objects, of which I ultimately need about 20,000 objects. I understand that I could join all 4,000,000 objects, but that would take a considerable amount of time, which I want to save.
My idea is to select the required objects in FC A and create a new list using the join attribute. Later, I want to use the FeatureReader and a WHERE clause query to read and process the required objects in FC B. Unfortunately, I am having a problem with the creation of the WHERE clause, so no objects are being read.
My workflow is as follows:
  • Read and select objects from FC A
  • Prepare the join attribute for the WHERE clause (add quotes)
  • Create the list using the join attribute
  • Convert the list to a string with commas as separators
  • Read the objects using FeatureReader
Everything seems to work except for the last step. If I enter the WHERE clause manually (without the list), it works. Below is my current workflow.
Anyone can help me, please?
Best answer by s.jager
Hi Alfons,
I have a very similar case, which I solve by using ‘,’ as separator character in my ListConcatenator (so apostrophe comma apostrophe, without spaces in between), then a StringConcatenator to add an apostrophe at the start and at the end of the concatenated result. In effect that creates a string that looks like this:
'value1','value2','value3'
Which can then be inserted in the where-clause (in my case of an SQLExecutor) using
where ColumnName in (@Value(Concatenated_Result))
and that works just fine, even if there is only a single value.
HTH,
Stefan
s.jager
Forum|alt.badge.img+27
  • Jun 20, 2024 2:36 PM UTC
Hi Alfons,
HTH,
Stefan
