Read XML and write Output in ArcSDE
  • Jul 30, 2021 7:57 PM UTC
  • 106 views
zentnerfabian
Forum|alt.badge.img+5
Hey guys,
I have XML Meta data files which I read and aggregate to one table to write them in a ArcSDE. The SDE is an Enterprise Geodatabase and the platform is SQL Server. To Connect to that SDE I need username and password. I use the FME Workbench directly in ArcGIS Pro and my connection to the database is existing. When I use the Writer "ArcSDE Geodb" FME is asking me for "Connection file". How do I get such an file? Or is there another way to publish the output directly in the SDE?
Thank you in advance!
Take care
Cheers,
Fabian
Best answer by panda
You may have this already figured out by now. But i'll try to answer it anyway.
When you connecting to SDE you have to provide these information known as Database Connection. if you right click that .sde file in Catalog pane and hit properties, it will give you the location path of that file. I believe you have to provide that .sde file path to FME.DBC_14CExySmLgq
panda
Forum|alt.badge.img+20
  • Jul 22, 2022 11:50 PM UTC
zentnerfabian
  • Aug 10, 2022 5:04 PM UTC
Thank you for answering my question. I figured out already.
