Read multiple shapefiles and write to GDB
  • Mar 11, 2020 10:39 AM UTC
  • 9 replies
  • 481 views
I have a harddrive full of data I need to turn into a good database, essentially.
I'm starting with converting any shapefiles into feature classes. I know how to convert one shapefile into a feature class, but I'm struggling with multiples that live in multiple areas/folders.
I've got two workspaces setup so far.
  • One is a read/write on ALL information in the hardrive. It writes a CSV so I can see what data exists. You can see the PATH in the photo below to see the data this reads.
  • The second is where my reader is set to read all .shp using the following to work through all "\\**\\*.shp" however this obviously does not read the underlying datasets that work together with a ShP to create it (.dbf .prj etc)
The write is a Feature dataset and the second is just a GDB set to fanout.
None seem to really do the job. Some export just a table, some just two feature classes.
I'm not sure if there is more I need to do within the workspace to process Shapefiles. I can't seem to find much documentation on shapefiles in FME or transformers.
It also doesn't help I'm working with ArcGIS Pro and not Desktop (which I'm experienced in), so understanding that along with this isn't the most straight forward.
Can anyone help?
Best answer by chandan
Hello @kimburrows1242,
Try attached workbench (FME 2018.1), hope it will solve your problem.
shapetogdb.fmw
chandan
  • Mar 11, 2020 11:38 AM UTC
shapetogdb.fmw
shapetogdb.fmw
Perfect. Thanks so much!
This doesn't seem to search for shapefiles within further subfolders. I've tried \\**.shp /*.shp /**.shp. Any ideas?
Forum|alt.badge.img+54
  • Mar 16, 2020 12:37 PM UTC
Try \\**\\*.shp
Try \\**\\*.shp
Thanks and do you think that will go through all sub-folders and their sub-folders etc or just one set of sub-folders?
  • Mar 16, 2020 3:04 PM UTC
That should look in all sub-folders and their sub-folders
sekarjntu
  • Dec 5, 2024 8:44 PM UTC
shapetogdb.fmw
It is asking for arcgis setup in fme server which we dotn have..is it mandatory to install arcgis in fme server to work with fgdb files
sekarjntu
  • Dec 5, 2024 8:45 PM UTC
can some one please help me how to read gdb file  in fme without installing arcgis
tomf
Forum|alt.badge.img+31
  • Dec 6, 2024 1:11 AM UTC
You can read and write to fGDB using the Open API format in FME without needing an ArcGIS installation.
Quick Add fGDB Open API Reader
 Be aware though that this format does not have all the functionality of the native File GeoDB format. https://docs.safe.com/fme/html/FME-Form-Documentation/FME-ReadersWriters/filegdb/filegdb.htm
