Read CSV multi-line header to define attribute value
  • Oct 13, 2021 6:29 PM UTC
  • 6 replies
  • 197 views
nataliekovach
I am really, really new to FME and so trying to wrap my head around everything. Essentially I have a CSV that has multiple data sets one after another, split by a multi line section of header information that it not formatted the same way as the data. I'm trying to read each section of data and write it to a single database table. So for each section I need to read a specific line within the header area (Serial number and Counter Name) and then use that as one of the attributes in the writer.
Data should look like :
SerialNumber, CounterName, Date, Time, Value
When complete in order to write it to the table.
From the various posts I've found I think it might involve using a variable setter and variable retriever but I'm not sure how to make that work.
Any suggestions are appreciated.
FME Csv read
danilo_fme
Forum|alt.badge.img+58
  • Oct 13, 2021 8:43 PM UTC
Hi @nataliekovach​
Please, could you share us the sample of data?
Thanks in Advance,
Danilo
nataliekovach
  • Oct 13, 2021 8:52 PM UTC
Here is a sample file.
danilo_fme
  • Oct 13, 2021 9:23 PM UTC
Thanks your data.
I created a Workspace to split and work with attributes.
Workspace_CSV
Attached the Workspace template (.fmwt ).
Thanks in Advance,
Danilo
nataliekovach
  • Oct 14, 2021 4:08 PM UTC
Thanks very much, that's definitely a start. Trouble is there are multiple sections of data within the file, each with a different serial number and counter name, so I need to be able to somehow recognize when a new section is encountered and then pull the serial number and name to apply the the following records.
The end data should look like this with each serial number and counter name for the applicable rows.
Sample End Data
Forum|alt.badge.img+54
  • Oct 14, 2021 4:31 PM UTC
Adjacent Attribute handling is your friend here, you can set the value of Serial Number and Counter name each time a new one is encountered, otherwise each record takes the value from the record above
Capture
nataliekovach
  • Oct 15, 2021 4:01 PM UTC
That is a thing of beauty, thank-you so much. This really helps, plus I'm learning all kinds of neat stuff.
